:smile:Hi there, I'm curious to know if some of you worked on electrical motor-driven pumps before? I've experienced some undercurrent trip problem; I wonder if it is always associated with the flow rate in the pump? electrically, the motor and starter are functioning well. the relay would sometimes take it out on "undercurrent trip", so we would tweek the relay setting a bit just to give a bit more tolerance. thanks all.:smile:
