Hello, and welcome to the Forum. I think there might be a little hesitance to answer your questions, as you're not an Electrical Contractor (according to your profile). So it might be a good idea to clarify if your question is for a project at work or something you're planning to do at your own home, as Forum rules prohibit us from helping with DIY projects. I'm a licensed Electrical Engineer, and I can't get DIY advice here either -- just the way it is.
I'm putting in a dedicated circuit for a sink disposal. Yes, I understand there is some controversy whether a dedicate circuit is even required by code or not. However, just because I can and because I want to be as compliant as possible with 210.19(A)(1), I am just going to take the time and put a dedicated circuit in for the sink disposal.
The placement of the electrical outlet box is a tiny issue though as it is going in the same cabinet as the sink. You know how electricity and water don't mix? So yeah, there are obviously going to be hot and cold water lines supplying the sink.
So, where in the kitchen sink cabinet... Or maybe I should ask... How high up do you guys rough-in the electrical outlet box for an electrical outlet powering the sink disposal? We are talking before drywall here. And, how about a GFCI outlet?
I don't really feel comfortable answering the question about exact rough-in height -- that's something we usually leave up to the Contractor. Enough things get changed last-minute in the field that I'm not aware of (small changes to cabinetry, sink location/style, etc.) that it makes more sense to let the guys in the field decide where will be best. The EC can usually talk to the cabinet guys and the plumbers (or at least to the GC), and get a pretty good idea of where the best location will be -- I can't do that from behind my desk. I've found that an Engineer who tries to micromanage exact locations usually just ends causing a bunch of problems that could have been prevented by letting the guys in the field use their own expertise.
As for whether or not to use a GFCI receptacle, that depends on what code cycle you're on. If it's 2011 or earlier, I'd say GFCI is not required, as it only requires kitchen receptacles that serve the countertop areas to be GFCI protected (see NEC 210.8(A)(6)).
If your project will be built under the 2014 NEC, though, then GFCI will (IMO) be required by 210.8(A)(7), which eliminated the exemption for kitchens. You'll find varying opinions on whether or not you're allowed to locate the GFCI device under the sink -- some say you need to use a dead-front device above the counter. However, I couldn't find any requirement for this particular GFCI device to be
readily accessible, so I guess I fall into the camp that says the GFCI is allowed to be located under the sink. Whether that's a good idea or not, is a design issue.
