Benihana
- Suffolk County, NY
- Electrical Engineer
Is there a section in the code that explicitly states if electrical panels can be tapped ahead of the buildings service disconnect switch?
Also, if this is allowed, are there any special considerations for how the panels should be wired? Does them being tapped ahead of the service disconnect switch have any impact on wiring the ground or neutrals? I'm mostly wondering if a neutral-ground bond is needed at these panels, or if the same rule of having the neutral-ground bond only at the service disconnect still applies.
Thanks!
Thanks!
