PE (always learning)
- Saint Louis
- Professional Engineer
Hope everyone is doing well,
I wanted to get a second pair of eyes on an electrical room that I'm laying out that has a 4000 amp switchboard (MSB). I just want to verify that this electrical room isn't causing any violations and that I'm not missing anything required from NEC 110.26. For instance, I have egress doors on opposite ends of the electrical room. Do these need to be right across from each other? I would think as long as the panels don't obstruct the egress path then I should be fine. Also, I have a panel L1 that could potentially open up into the south egress door, I'm wondering if this should be moved. Electrical room image is attached, any advice is always appreciated.
Best Regards
Best Regards
