Alwayslearningelec
- NJ
- Estimator
I'm sure have heard the term "rough in". Where did that come from? Also it's rough in and NOT roughing, correct?
And applies to other trades as well…..HVAC and plumbing, for example.Rough-in is the more common term. It's a phase of the job before the walls and ceilings are closed in.
Yes got it but I was curious where the name was derived from.Rough-in is the more common term. It's a phase of the job before the walls and ceilings are closed in.
That's great. I have one trimmed out and one roughed in....lolI remember sitting at the break table once when someone asked another electrician how many kids he had, his reply was "two trimmed out and another roughed in"
Rough, meaning not finished, so rough-in is the process of laying the ground work to get it ready for finishing.Yes got it but I was curious where the name was derived from.
YesWould you consider pulling wire through branch EMT part of rough in?
Sometimes the wire is pulled later, but if it is, you need to add at least 50% to your wire pulling time. Not being able to walk through the walls or to see the conduit routing adds additional labor hours.Would you consider pulling wire through branch EMT part of rough in?
