OBONE
- York Region
- Electrician
Hi. I was called to a residence regarding voltage spikes within the house. The readings vary but for the most part when the fridge or other appliances come on the voltage spikes on one leg to 180 volts and the other leg drops sometimes as low as 70 volts.
When the system is "normal" readings are good at 125 volts and 247 volts . Is this a grounding issue?
