electrical
Re: electrical
This sounds like an exercise question.
Let me ask you. . .what is the formula that relates power (in Watts) to Volts and Amps?
Therein, with a little arithmetic, lies the calculated answer.
Spelling will be my downfall -- Al
[ August 21, 2005, 04:32 PM: Message edited by: al hildenbrand ]
Re: electrical
Originally posted by Andy Catoe:
what is the current drawn by a 250 watt incandescent lamp operating at 120 volts
That would be Amperes. ;)
We are not doing your homework, tell us what you come up with and we can help you.
Re: electrical
I don't know why these guys won't tell you the answer, it is twice the current flowing of a 250 watt lamp operating at 240 volts, gee guys. :eek:
Roger
[ August 21, 2005, 04:59 PM: Message edited by: roger ]
Re: electrical
I thought we were talking about "home slaw." I like home slaw. My doctor told me I needed more fiber in my diet. :D :D
Re: electrical
I'll help you out Andy.
Ohm's law has three diffrent forms that are all the same thing, just rearranged algebraicly.
V=IR
R=V/I
I=V/R
V is Voltage (volts)
R is Resistance (Ohms)
I is Current (amps or Amperes)
Power is measured in watts and is the product of voltage and current and can also be written in three ways:
P=VI
V=P/I
I=P/V
What you have to do is find which form of the two basic equations, (V=IR and P=VI, all six forms are here), work with the information you have.
Edit: It helps to know that any equation AB=C can be rearranged in these three ways.
[ August 23, 2005, 07:57 PM: Message edited by: physis ]
Re: electrical
I once applied to an outfit called something like RedHat. They had a quiz. One of the questions was:
"What is the amperage of a 1200 watt light bulb at 120 volts?"
I guessed 10 amps and got it wrong. I didn't get the job.
~Peter
Re: electrical
You are right, "boss," it was. It was my attempt at sick engineering humor. :roll:
I would be curious to learn what "they" thought the correct answer to be. But Peter didn't get the job (probably lucky for Peter), so we'll likely never know. :confused:
Re: electrical
I just left it alone because I though it would be the best course of action, sometimes I accidently make the right call. :)
Re: electrical
Peter's test experience is one of those things that gets my back up.
Re: electrical
~Peter
Perhaps a trick question. I can't say I've ever seen a 1200 watt incandesant lamp. If it were a HID lamp of some sort, you would have to consider the ballast, which would change the numbers a bit. Then again, I don't recall ever seeing a 1200 watt lamp of any sort, so maybe they're just insane. :roll:
Re: electrical
~Peter
-cs
rest easy. I was just using the 1200 watt bulb to make the calculation easy.
[ August 28, 2005, 12:18 AM: Message edited by: peter ]
