Andy Catoe
New member
what is the current drawn by a 250 watt incandescent lamp operating at 120 volts
That would be Amperes.Originally posted by Andy Catoe:
I am with you Bryan, that is clear to me.Originally posted by bphgravity:
A = W / V.
I'll help you out Andy.what is the current drawn by a 250 watt incandescent lamp operating at 120 volts
Of course you did. The correct answer is "red."Originally posted by peter:I guessed 10 amps and got it wrong.
I believe that's the point al.Originally posted by al hildenbrand:
Huh?![]()
Perhaps a trick question. I can't say I've ever seen a 1200 watt incandesant lamp. If it were a HID lamp of some sort, you would have to consider the ballast, which would change the numbers a bit. Then again, I don't recall ever seeing a 1200 watt lamp of any sort, so maybe they're just insane. :roll:Originally posted by peter:
I once applied to an outfit called something like RedHat. They had a quiz. One of the questions was:
"What is the amperage of a 1200 watt light bulb at 120 volts?"
I guessed 10 amps and got it wrong. I didn't get the job.
~Peter
OK, so maybe I'm the one who's insane.Originally posted by peter:
~Peter
-cs
rest easy. I was just using the 1200 watt bulb to make the calculation easy.
