electrician
COLDLAVA
is there a process of amping parallel feeders, using the standard amp probe or is the a device on the market for that purpose?(standard amp probe can only close around one 500mcm at a time)
mdshunk
Right here.
Get a bigger amp clamp. They also make flexible one's for going around bus bars and stuff like that. I don't know how big my biggest one is, but I've been around a bundle of 8-4/0's at a DC plant.
Testing each one is of less value, unless you're hunting a suspected bad termination.
wirenut1980
Plainfield, IN
Yep, flexible CT's. Check with your meter manufacturer. I'm sure they will be happy to sell you some.
brian john
Leesburg, VA
My largest has a 48" diameter I have used ones with 72" diameter. Though I have not done this an engineer I worked with said he used two LEM's*1 connected together. I guess I should try this next.
*1 Brand Name For Flexible CTs.
cschmid
I wonder how much marc and Brian have in cool toys..I have a fortune and I am amazed every time they list stuff I don't have..:rolleyes: but I get new ideas:grin: my wife might just thank them when she sees the bill:grin:
charlie tuna
Florida
biggest i have are 4000 amp --split core type. center opening is about the diameter of a football!
as noted above: do each individually and add them up ---they should(?) be fairly close if they are the same length?
