Al Pike
 - Honesdale, Pa
How Does An Underground Location Get Classified1 Divison 1?i Have A Duplex Pump Station With  A Electrical Rack And Gen Set 20' Away.i Would Like To Use Pvc(with Encasement) Underground With Rigid Sweeps And Rigid Above Ground.
Also Can I Seal The Conduits At The Duplex Control Panel At The Rack From The Wet Well, Or Will I Also Need Seals At The Top Of The Wet Well For The Junction Box For My Conduits? Im Guessing That The Area Where The Rack's Located Was Not Classified C1,d1 Because The Rack Equipment Is All Nema 3r. Does This Make The Entire Area Out Side The Wet Well Unclassified? Need Help Thanks.
