Hello.........
Is it permissible to take a grounding electrode conductor from a water meter and a grounding electrode conductor from a ground rod, and take those two grounding electrode conductors
and splice them (or attach them together with a ss connection (buss bar) or bug) outside the panel and bring one grounding conductor to the neutral/ground bond.
I think it is ok.........but I'm pretty sure that splice would have to be exothermic weld, or pressure crimp, or bolts that don't back up....
Where might I find this article please....
Also, most recently, I installed a service with two 100 amp single phase drops to two meters to two panels....... I was going to install the electrode grounding as one 200 amp service and jump the two panels at the neutral/ground bar...............
The inspector wanted the grounds to be crimped.............
I instead grounded each panel as a 100a to the water meter and the ground rods....
I will look through 250,,,,,,,,,,,,,,, and lead is appreciated...
Thank you.
Thank you.
