Elevator motor size?
shortcircuit1
USA
I am a little confused with this elevator specs.What is the size of the elavtor motor according to these specs?I want to say its 14.4 or 15HP cause its defined as rated motor output.Am i right on this?
I vote yes.
Interesting that the drive rated power is lower than the motor size. It’s fine given that the actual load power requirement is within the drive rating, just indicative of the elevator business being exceptionally cheap.
Now the question is, since the drive can’t deliver more than 10 HP, do you size the circuit based on that, or based on the actual motor rating (15HP)?
