Can below conduits run above ground (8 - 9 feet above ground) or use outdoor bus duct for the run. This is an existing hospital.
1) From outdoor emergency generator to main emergency distribution panel (located outdoor) to emergency load ATS (located inside the building)
2) From outdoor emergency generator to main emergency distribution panel (located outdoor) to fire pump controller/ats (located inside the building)
