Tanelectrical
- Washington
- Government worker
I am upgrading my panel to a 200amp service. When the utility company pulled my meter I discovered that my meter base was damaged. My question is do I have to install an emergency disconnect outside per Washington state code. I understand new construction requires a disconnect. My other question is if I have to put an emergency disconnect on the outside of my house does that mean the panel I have now with a 200 amp disconnect needs to be changed out with a panel that does not have a disconnect ? I do understand the bonding and grounding would have to be diffrent
