I have seen emergency lighting done different ways and was wondering what the best or correct way was. Do you provide a seperate circuit for emergency lighting or can you use the same circuit as the room lighting is on?I looked in 700.17 (1) and if i understand it correctly then you need a seperate circuit. This would also allow you to check the battery life IE 90 MIN. CORRECT?
