Does the NEC permit emergency lighting to be controlled by an occupancy sensor?
What code section does that appear?You will need a UL924 transfer device for any occ sensor that is controlling a fixture used for life safety egress. This can get expensive real quick. Is it possible to use wall pack fixtures (bugeyes)? This would alleviate the need for additional lighting control components.
According to my knowledge, UL924 should be used to transfer control wiring, UL1008 should be used to transfer control wiring and power wiring.You will need a UL924 transfer device for any occ sensor that is controlling a fixture used for life safety egress. This can get expensive real quick. Is it possible to use wall pack fixtures (bugeyes)? This would alleviate the need for additional lighting control components.
Sent from my ONEPLUS A6013 using Tapatalk
