mdshunk
- Right here.
George's incident makes me like cable pull e-stops and light curtains even more.
In most cases, the estop should be thought of as a way to protect the machine or the product from mechanical damage rather than to protect the operator from the machine.
edamico11 said:Can you please explain this?
patersonra said:It is not an acceptable practice to install an estop for the purposes of reducing the level of injury, and think you have done yourself a favor. If you know there is a risk of injury, the correct answer is to deal with that risk head on and get rid of it.
edamico11 said:I'm sorry I just do not agree. There is no such thing in design (IMO) as ridding oneself of risk. You can attempt to build the safest situation, but risk will always be there. It is not possible to calculate all the different situations one will fall into once the system, you designed, is in use. So in my systems if there are moving parts, an estop is there, not because I did not design a safe situation, because I know emergencies happens everywhere.
