I'm designing a new facility (airport terminal) in which there are 700, 701, and 702 loads. The generator is located outside the terminal. According to the NEC 2005 handbook section 700.9 (blue print) I can run one feeder from the genererator into the building and terminate it in a switchboard (not a panelboard). From the switchboard I can then go out to my three seperate transfer switches and there corresponding panelboards. My questions are:
A) Can the switchboard, all three transfer switches, and the panelboards all be located in the same room. (It is a seperate room away from the normal service electrical room.)
B) What should the fire rating of the room be? Arcticle 700.12 states minimum of 1 hour. NFPA 110 section 7.2.1.1 states 2 hours although this is when the generator itself is within the room.
I have asked numerous others and I have recieved numerous answers. Just hoping for some opinions!!
Thanks
BG
Thanks
BG
