LarryFine
- Henrico County, VA
- Electrical Contractor
Consider throwing the main when dis- and re-connecting.ill try that tommorw and see what happens![]()
That's the reasoning behind my suggestion. Current in the electrode and its conductor form a large circle that should collapse when it's opened.
Also, before you disconnect it, comparing electrode current while energized and de-energized will show whether it's your neutral current or a neighbor's.
That makes it yours. On to the next experiment.i did shut off the power one time and had 0.0 amps on the GEC
Ben Franklin would call ou a wuss. :wink:i will do the experiment when its not thundering and lightning out just in case![]()
