I have been told a bunch of different things on running romex in EMT:
"Yea you can but not "heat rated"
" - home depot guy...
"Sure its ok but you have to derate your wire after a certain length"
"Nope, can't do it" - another home depot guy...
Are you allowed to run THHN romex in EMT pipe?
our garage has a GFCI outlet near the garage door where we hang our hand tools like shovels and all and the wires always getting banged up. I want to run these two wires, which go from the outlet on the wall to the corner of the room which is only a foot away from the outlet and then they lead over the frame of the garage door...I wanna put these in EMT pipe starting from the outlet box and ending at the top of the garage door frame which is away from any danger.
These are 2 lines of 14-2 romex. Actually i'm not really sure about this wire as I have never really seen it much before. It's light blue in color and had the following text on it:
"E18679 (UL) AWG 14-2 WITH AWG 14 GROUND TYPE NM-B 600V"
If anyone has any info on this wire that would help too.
photos of the wire:
photos of the wire:
