Doc13067
- Bucks County/Philadelphia, PA USA
I know that EMT can be used as a ground if properly bonded and secured at the fittings (250.118 (4)). Does anyone know if there is a limit to the amount of amperage running through the EMT without a grounding conductor in the form of a wire? For example, if I run a single light fixture with EMT and just have a hot and a neutral wire with the pipe acting as ground that is fine - could I also run 20 circuits with just hots and neutrals with the only ground being the EMT? Or is there a certain point where you need to run ground wires in the pipe?
What I’m trying to do is run circuits from a new panel to an old panel, all in one length of EMT, because the old panel contains all the branch circuits and the old panel is being converted to a junction box. Trying to avoid running grounds for every circuit since the pipe can be used as a ground.
keep in mind this is assuming all other variables are done properly so conduit fill, secure fittings, ground wires ran from boxes to devices etc. I am strictly asking about the ability of the pipe (EMT specifically) to serve as the ground and any limitations that exist. Can’t find this info anywhere. Thanks guys!
