DSamson
- San Francisco, CA
I'm replacing an old fuse panel in a hallway closet with a circuit breaker panel in the hallway nearby. To extend and relocate the old branch circuits, I need to run EMT between the old fuse panel and the new circuit breaker panel.
The EMT needs to go right by some old Knob & Tube (K & T). Most of the conductors in the old K&T are Type TW and are in loom in the relevant area. Some of it is Type R, wihtout loom in certain places (i.e., along the inside face of a stud, between knobs).
Are there minumum clearances required between K&T and EMT? Code section?
Can I go zero clearance if I make sure all of the conductors in question are covered with loom?
If not, is there another insulating material available that would make this proximity permissble?
Thanks, as always for the great help you all provide.
