Hi, I need to run a conduit on a foundation wall low to the ground.
2-1/2" for the load side of a 200 amp meter main.
Does the closeness to the earth bother anyone for EMT? Thinking about corrosion over time.
We could run PVC as an alternative but it seems EMT might look nicer.
Would need to run under the window and then kick up a bit as the grade rises to stay under the mini split.
