peter d
- New England
I would not run PVC on a roof, EMT or IMC for me.
Everyone has their preference and opinion![]()
:roll::roll:
rooftop PVC. it needs to be protected from sunlight. since most paints will fall off over time, if it will be exposed to sunlight everyday then i myself would not use PVC. there are wraps that can be used (pita). you also need proper expansion joints if needed.
You clearly have zero experience in the electrical trade and should not be commenting on wiring and installation practice.
i am very familiar with PVC compounds, it will all (gray, white, blue, black, pink, red, whatever) degrade when exposed to UV, makes for a poor choice when exposed to sunlight.It is required to be sunlight resistant.
for the purposes of curiosity, i will entertain your rhetoric here. care to enlighten us?You clearly have zero experience in the electrical trade and should not be commenting on wiring and installation practice.
no, they dont disagree with me, "electrical PVC", otherwise known as PVC with UV stabilizers in it, is the best plastic for the job currently. HDPE will eventually take over. [FONT="]UL651 is ok but it doesnt really give us the full story. PVC will become very brittle. check with some of the electrical contractors in FL,TX,AZ and see what they say about PVC on rooftop. it becomes very brittle over time and ease of cracking becomes an issue due to a slight bump. if its PVC many will coat it with a coating to extend its life. the question was PVC or metal, i would use metal on rooftop.[/FONT]I don't know much about PVC but so far the NEC disagrees with you.
the industry is slowly but surely moving to HDPE. in the near future NEC will have to add "HDPE" as a conduit material type.
no, they dont disagree with me, "electrical PVC", otherwise known as PVC with UV stabilizers in it, is the best plastic for the job currently. HDPE will eventually take over. UL651 is ok but it doesnt really give us the full story. PVC will become very brittle. check with some of the electrical contractors in FL,TX,AZ and see what they say about PVC on rooftop. it becomes very brittle over time and ease of cracking becomes an issue due to a slight bump. if its PVC many will coat it with a coating to extend its life. the question was PVC or metal, i would use metal on rooftop.
the industry is slowly but surely moving to HDPE. in the near future NEC will have to add "HDPE" as a conduit material type.?
353 High Density Polyethylene Conduit: Type HDPE Conduit
353.12 Uses Not Permitted. HDPE conduit shall not be used under the following conditions:
(1) Where exposed
you have a hard time of understanding. i never said PVC could not be used, i said my choice would be metal.Yes, based on this posting below it is very apparent you don't understand wiring methods and what is and is not allowed by the NEC.
You also need proper expansion joints if needed.
And you tried to substantiate that claim by saying that PVC would get brittle and break with the slightest bump. Of course it will get brittle over time and break if something were to hit it. But EMT and even RMC degrade over time as well.
i guess you missed my point, if UV is killer, use metal, if moisture is hi, use PVC. i guess s FL you have to pick, but if HDPE was available i would use HDPE over metal in s FL.
true. in AZ where avg humidty is ~35% and rain happens a few x a year, metal is better. in FL, salt water is a nightmare for metals, PVC is better choice. OP is on LI, humidity is rather hi there for most of the year and UV from sun is not so much (too cloudy most days), so maybe PVC is better.
So now I started an argument and I'm still unsure on which is the best method to go with.
I live in New England, the climate is exactly the same as Long Island and that's why I would not use EMT. It degrades and rusts very rapidly here.
art 353, what about it??And I guess you cannot read my post above.
It is a violtion to use HDPE expossed.
