Emt Raintight Fittings
PWR73
Can One Use A Emt Raintight Fitting In Lieu Of A Meyers Hub For Entrance Into The Top Of A 3r Panel?
If the EMT connector is raintight why would you need a Meyers hub? Doesn't the 3R panel have a hub on the top that you would be threading the EMT connector into?
The link Big Vic posted said:
Connector internal sealing ring and external knockout gasket
prevents water seepage into conduit, box, or enclosure.
So it looks to me like that should be OK.
The only listed fitting i know of is a meyers hub to do this job.What your suggesting is using what ? o ring ? Where is your ul listing ?
