- Massachusetts
Jim I think a lot of times when we think 'why did they do this?' that the answer is they did not, at least no directly.
Sometimes when you make or change a rule one place it effects other rules in strange ways.
I do see your point about the 5' exception.
This nipple question might be solved by just putting in a proposal.
I have not supported many EMT nipples between enclosures and have never had a an inspector question it. I think if the installer uses some common sense most inspectors would as will as well.
If I have 2 enclosures 24" apart and I run an unsupported 2" EMT between them it will be rock solid and I doubt an inspector would have an issue with it. I would not do the same thing with 1/2" EMT.
