Is this EMT run adequately supported, please reference code section?
I can tell you it's not because that's MY photo, and I never claimed it was properly supported.
I only see 1 piece that could have been properly strapped.
The rest of it would be a major pain, if even possible to strap.
"If" I were the inspector I would have asked for the verticle to be strapped and moved to the next room.
It was all strapped. And the entire job took about 10 minutes to do. Not just what was in this photo... the entire job.
Erico & Caddy make straps just for this installation.
.........The company that I work for everything we run is exposed and surface mounted so I've never had to worry about support in walls. ...
I hope you're kidding. Most people would never accept surface-mounting pipe & boxes on new work.
Nope, Check your PM's I'll send you a link to our business.
Well, those are a weeeeee bit different than the optical office the photo is from.![]()
I'm interested, too.Nope, Check your PM's I'll send you a link to our business.
358.30.. which uses both the terms securely fastened and supported. For the most part, EMT must be securely fastened. It is only horizontal runs which are permitted to be supported by framing members. I always wonder about this one... what about runs which are only partially horizontal???Is this EMT run adequately supported, please reference code section?
Has anyone here read
358.30(B)?
358.30(B)?
