EMT to Liquidtite conector
mtfallsmikey
Does any manufacturer make a one-piece transition adapter to go from EMT to Liquidtite vs. using box connectors/threaded couplings?
Liguidtite and Raintigh are different conditions, if you need a liquiditite installation, emt may not be the best choice.
Satcom .... I tale 'liquitite' to be another brand / trade name for what others may call sealtite or greenfield. Liquid-tight flexible conduit.
I have not seen a 'transition fitting' for the use.
EMT is no more or less raintight than any other solid walled raceway. Fittings are where any leakage is going to happen and can happen with any type raceway.
If installed in area where condensation will occur - it does not matter which type of raceway is being used - the condensation will happen and has nothing to do with rain tightness.
Just received new edition of Electrical Contractor Magazine today. Bridgeport ad on back of front cover has picture of exactly what OP is asking for, as well as other transitional fittings.
