Charlie earlier indicated a "Nut and Threaded" connector. (Compression).
Are Set Screw Connectors not acceptable ?
Ive seen several specifications that allowed compression fittings only. Even if it were indoors. And was curious if there was some issue with set screw connectors not establishing a sufficient ground path that I wasnt aware of.
emt connectors come apart all the time. why would you not run a ground wire?
Don't set-screw connectors have a nut and threads on the end of the connector?
Charlie didn't say anything about a compression fitting.
Yes it happens...to the same installer who does not make proper connections to the EGC within the EMT.I've heard the same claim about pvc40 in a trench. bottom line, it happens.
