FrankMarchica
New member
- East Meadow, NY
Is it legal to use EMT outdoors. There seems to be much discussion about this among many electricians I speak with
Along with Ron's post, are you sure these are electricians discussing this? Even if they are not aware of the article section Ron posted surely some of them have heard of "Raintight EMT Fittings" which in itself would be the answer to the question.Is it legal to use EMT outdoors. There seems to be much discussion about this among many electricians I speak with
Some local jurisdictions may prohibit it's use due to local climate conditions.
In New York City EMT is not permitted in wet locations.
Can you name any? Ones with real written prohibitions not simply tradition?
Interestingly, NYC amendments indicates to delete the Subsection 358.10(C) (Wet Locations) in its entirety, but doesn't add Wet locations to 358.12 (Uses Not Permitted).
Some feel that EMT is ok in NYC wet locations, since it wasn't added to 358.12 and you are just not encumbered by the special requirements set forth in 358.10(C) for wet locations.......
By deleting the permitted use in it's entirety the wiring method becomes prohibited so no need to add it to the Uses Not Permitted.
Then couldnt one argue that it makes no sense to have BOTH a "uses permitted" and "uses not permitted" list?![]()
