paul renshaw
- Cordova, Maryland
Is it legal to fasten conduit (EMT) to a water or steam line? There was an install done in our plant like this and I'm trying to find a code section that prohibits it.
I don't know of any section that prohibits it.Is it legal to fasten conduit (EMT) to a water or steam line? There was an install done in our plant like this and I'm trying to find a code section that prohibits it.
Are the two conductors powering two separate indicator lights?I also just noticed that they ran two conductors that feed 120V to indicator lights in this conduit from a valve, with no neutral, and picked up a neutral off of an ice cube relay that is in the cabinet where the conduit ends. The valve 120 volt and the cabinet 120 volt are from different sources, but they just tapped the neutral fromthe other source, plus used flexible cord as a permanent connection.
But yet if another trade hangs something off your raceway.....I've attached to other piping before without issue. I won't run 100' of conduit strapping to the side of it but sometimes you need to hit a piece of equipment a little ways off the wall or in the middle of a room and the only way out there is to throw a piece of strut across another pipe and strut strap it and your conduit together.
I don't think it is either. I also would have to wonder why the steam line is not insulated, to reduce heat loss as well as for safety.They are hung with minerlacs back to back, and the conductors each feed a separate indicator, no neutral in the conduit with them, they just tapped a control relay in the cabinet, which is from a different source. I'm going to get the engineer involved in the steam line mounting, I just don't think it's a real good idea.
