- Licensed Electrician
Cool. I won't install it outdoors here for any reason.
That sea level air is some harsh stuff, too much oxygen, glad I don't have to deal with it.
Is that an actual code or just a job spec?
358.10 - Uses permitted.According to the NEC it can be installed outdoors correct? What code article references that?
Pretty sure it's just the unions wanting to increase the labor costs, just like how FMC can't be used in ceilings, no?EMT in NYC is banned outdoors. Probably because of acid rains.
If you would ask for raintight emt connectors in supply store they would think you are nuts.
We use aluminum RMC most of the time. It's connectors don't have the raintight listing.
I think he meant there is no demand for raintight connectors because you can't use EMT outside (there) so the supply house won't have any.How do you satisfy 344.42(A), if the connectors aren't listed for wet locations?
