zrjohnso said:
... please expand on "set the gearing to overspeed the motor 1% - 5%?" I don't have much experience with motors yet. ...
With your major, you may never get much experience. You're going to have to learn on your own. Hence the suggestion to get one of your power option buddies to give you a hand. However, it was third year/fourth year befor I got close to a decent power lab.
That was long enough ago, as Iwire alludes, I think we were still watching TV by candle light.
Motor speed for an induction alternator:
First this is 3 phase, not single phase - you're not going to connect this to a house circuit.
Induction motors turn slightly less than synchronus speed. At rated power they will turn 3% - 5% slower than synchronus speed. For example, consider a 4pole induction motor. Synchronus speed is 1800rpm. At full load, the motor will have a speed of 1750 RPM. This "slip is necessary for the motor to develop any torque.
If this same motor, electrical connected to the power source, has the shaft connected to a driver and the driver overspeeds the motor (same 3 - 5%), say to 1850rpm, a couple of things happen.
1. It takes torque to overspeed the motor - you have to put work into the motor to get it to overspeed.
2. This work comes out on the motor leads, as electrical power put back into the grid.
An induction motor used in this manner is called an "induction alternator".
So one would have to set the gearing between the driver and the induction alternator to operate the motor at 3% - 5% above synchronus speed. A 2pole motor would have to spin 3600 + 108 = 3708
I curious as to your purpose to want to "store your energy". If you are just screwing around to learn - great idea. If there is another purpose, we may needto know this to better advise.
If you are just after the learning, and the concept of an induction alternator is interesting, also check out a "double fed induction alternator". They are not so demanding on the speed they have to turn to produce power.
carl
