- Massachusetts
charlie b said:May I presume that the "stamp" to which you refer is not the one that is more properly called the "PE Seal"?
That is correct.
I also dug out one from a previous job to check it out.
It is a stamp with the Engineering firms info with a signature added of the particular engineer for the job.
It does not say 'approved'
It says
'Reviewed and found generally acceptable. Minor deviations may be noted. No further submittal required if notations are complied with'
I did not find any notations so it appears this is their standard 'approval' stamp.
