If you want to service the inverters, you just open the AC disconnect which is the backfeed breaker.
If you want to work on one microinverter but not disable the rest, unplug it from the AC wiring harness.
To service a panel, unlike with a string inverter, you just disconnect that panel from its microinverter, with or without disconnecting the AC side of the inverter. The only thing you need to take care with is that you shut down the inverter or cover the panel before disconnecting the PV at an MC connector. Those connectors are not designed to be unplugged under load.[
Interesting
Certificate of Compliance
Certificate: 2395707
Master Contract: 240080
Project: 2657873
Date Issued: October 4, 2013
Issued to: Enphase Energy, Inc.
1420 N McDowell Blvd Petaluma, CA 94954-6515 USA
The products listed below are eligible to bear the CSA Mark shown with adjacent indicators 'C' and
'US' for Canada and US or with adjacent indicator 'US' for US only or without either indicator for
Canada only.
Sarah Ugolini
Issued by: Sarah Ugolini
PRODUCTS
CLASS 5311 09 - POWER SUPPLIES - Distributed Generation Power Systems Equipment
CLASS 5311 89 - POWER SUPPLIES - Distributed Generation - Power Systems Equipment
- Certified to U.S. Standards
Utility Interactive Micro Inverters, Models M215-60-2LL-S2x, M215-60-2LL-S2x-NA, M215-60-SIE- S2x,
M215-60-SIE-S2x-NA, M215-60-2LL-S2x-ZC, M215-60-2LL-S2x-ZC-NA, M215-60-2LL-S2x-IG,
M215-60-2LL-S2x-IG-NA, M215-60-2LL-S2x-IG-ZC, M215-60-2LL-S2x-IG-ZC-NA, M240-60-2LL- S2x,
M240-60-2LL-S2x-NA,M250-60-2LL-S2x, M250-60-2LL-S2x-NA, M250-60-2LL-S2x-ZC and
M250-60-2LL-S2x-ZC-NA.
For details related to rating, size, configuration, etc. reference should be made to the CSA
Certification Record, the Descriptive Report, or Attachment 1 - Ratings.
Notes:
- AC and DC connectors evaluated for disconnecting under load (for this application only).
