jim dungar said:
I have just as much faith in properly mixed and cured epoxy as I do in properly mixed and cured concrete, after all they are both based on chemical reactions
It won't matter to you and me in a hundred years, but it might to someone else.
No offense intended, but comparing a relatively new product to one that has withstood the test of time (thousands of years) sounds somewhat cavalier.
Can you guarantee that the epoxy that you use will be stable and not de-compose, shrink or otherwise fail in the next 50 years? How about 10 years?
How about 100 years?
When it starts to fail (which I think will happen), who's to blame?
The comparison between anchors set in properly mixed and cured concrete verses properly mixed and cured epoxy resin may look good at present.
Will they (epoxy) stand the test of time?...I think not.
IMO, if the Big Dig engineers had used anchors tied to the steel and set in concrete, the roof panels would still be hanging. If the (failed) epoxy had been properly installed and cured, they still would have failed, it would have only taken longer.
Just a opinion
steve
