I am installing a fiber optic illumination source: 150w quartz bulb in enclosed unit, elevated 8"+ above ground level and with line connection electrical feed in conduit. Note has #8 bond connection to the unit.
Question 1: If possible I need to locate the enclosed lighting unit 7' from the pool. Will that distance meet my NEC 1996 requirement and what is the applicable paragraph?
Question 2: Please confirm GFI outlets fall under same rule as regular outlets (80.22(A)(2)?) and must be 10'clearance?
