AmazingTrans
- Australia
Hi there, i have been in practice to provide equipment ground based on the largest load on the equipment. I was never explained what was the NEC / standard justification of providing equipment ground. Today, most of my motor load runs in cable and they have ground wire that comes with the motors cables. This ground is either tie to the source ground, or tie into VFD drive ground point which I am going to guess it also tie to the source ground.
So, will i still need to provide equipment ground? If yes, what standard is this referring to?
Equipment ground = ground that ties the equipment to the source power ground.
If i remember correctly, in the past not many people uses cable that has ground wire that comes with it. And many users pull their own 480V to terminal blocks and a separate ground to the equipment. And this ground has to be able to handle 1 fault path and that the the largest load fault.
Hope to hear from someone. Thanks!
AmazingTrans.
AmazingTrans.
