Equipment grounding conductor ran with supply conductors to a separate structure
roger
Fl
Yes, see 250.32(B). The neutral is not bonded to the GEC or loadcenter so without an EGC there is nothing to clear a fault.
Roger
roger
Fl
Will this create a ground loop if the EGC is connected on both ends?
No, it's the same as connecting an EGC to any subpanel. Remember the grounded conductor is not bonded to the EGC or GES at the detached structure, it floats so there is no loop possible.
Roger
