Hi Everyone!
I have an existing cooling tower to be replaced in kind. The cooling tower is 30 HP @ 208V/3P and the conductors feeding it are (3) 2/0 (no ground), neutral is not needed.
I noticed that the existing tower does not have an equipment ground. Is there any other way to ground the tower without having to run a grounding wire back to the panel? The reason I ask is that we won't be able to fit a ground in the conduit + the panel is pretty far.
I couldn't find where the code says that you can't run a ground to another (closer) panel or other ways to ground the equipment other than the typical ground to the panel where the tower is fed from.
Please advise.
Thank you!
Please advise.
Thank you!
