timm333
- Minneapolis, MN
- Electrical Design Engineer
A question please. if I have a utility supply, then breaker with OC-relay which will act as primary protection of transformer, then transformer, then breaker with OC-relay which will act as the secondary protection of transformer. then MCC, then overload-relay plus breaker for motor, and then motor. In this combination it becomes hard to coordinate all three relays.
can I omit the breaker+relay of transformer secondary so that the primary of the transformer protects the cable and MCC on the secondary side of the transformer. The reason I was thinking to do it is because if i can omit one relay, then it will be easier to coordinate the remaining two relays (which will be motor relay and transformer primary relay.)
