jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
Still haven't done any of this myself. I am talking with my father in law about a new service for his farm buildings. He has an OLD main disconnect at service pole, fusible, with multiple taps off to a barn, several sheds & the house. Main is mounted on boards long decayed, hanging by a thread. Cables go through drilled or punched holes in sheet metal walls of buildings. Most cable has long been showing outer cu or al neutral.
He wants to tear down 1 shed, no problem there. Barn & other shed or 2 have concrete floors. For EB, I am thinking chipping off outer corners to find any rebar or screen wire and bonding to it, run a grnd wire all around, bonding to siding with open ground clamps & rebar/wire at each corner. Would this be effective in an existing building? Have any of you had a similar situation?
