Bonding the pump to the pool, the ground grid, and the metal is all that is required as I understand it. It is not there as a fault clearing mechanism.Where does the equipotential bonding conductor connect to once all the metal parts are bonded? How does this tie into the system in the case of a pool. When you bond the pump and all metal within 5’, where do you connect the other side?
