L lmchenry Senior Member Apr 21, 2009 #1 Can the 3 ft perimeter surface bond be welded wire? And also if it is rebar is there a limitation on how small or big the grid needs to be?
barbeer Senior Member Location Pinellas County, FL Apr 21, 2009 #2 680.26 is somewhat specific........maybe more so in the 08', however I would call your AHJ, there has been so much change and discussion you could have different requirements.
L lmchenry Senior Member Apr 21, 2009 #3 From the 08 handbook I see that wwf will suffice. However, I am still puzzled as to any specs on the rebar layout. Any suggestions?
barbeer Senior Member Location Pinellas County, FL Apr 21, 2009 #4 FOR AWHILE............FL said that 3/8 rebar laid in a 12x12 grid was the way to go.
