engrkira
- Philippines
Given a generator rated 50 Hz at 1500 rpm with a 3.9 kw. How can I compute the power if the generator was run into 60 hz, 1800 rpm?
Depends on the prime mover. That's what delivers the power.Given a generator rated 50 Hz at 1500 rpm with a 3.9 kw. How can I compute the power if the generator was run into 60 hz, 1800 rpm?
On average, doesn't a 50Hz motor or transformer deliver 17% more power on 60Hz? The higher frequency means more speed for the same torque, and 60Hz has a smaller magnetic circuit so a high voltage can be applied. Id imagine generators are similar in some respect at least to speed. I've seen Generator manuals where the same generator configured for 60Hz does put out something like 10% more power.
Here is one example where the same alternator is rated higher on 60Hz:
http://www.kohlerpower.com/onlinecatalog/pdf/g5365.pdf
http://www.kohlerpower.com/onlinecatalog/pdf/g5388.pdf
makes sense
Power = Torque x w (w = 2 Pi n, n = speed in rev/sec)
for a constant torque, increase speed, increase power
but many times for most engines increase speed and torque decreases if > peak torque rpm, hence instead of 6/5 or 20% more you only get 10% or so, speed increased but torque decreased
but in this case it is limited by the alternator rating
So if I connect a 30kW generator to a 5,000HP engine, I can get 3,000 kW from it?
I know what you meant, I just couldn't resist ribbing you for the way you worded it...![]()
In my opinion, theoretically speaking, a 50 Hz engine could work-even better-on 60 Hz-as already was said. However, it could be a limit for critical speed [usually it is not such a problem, agreed].
The forces acting on a shaft are very complex, but some of the more obvious ones are:
Unbalanced magnetic pull due to finite number of stator and rotor slots[induction machine mainly].
Centrifugal force due to rotation of shaft.
Force due to the torque transmitted from the driving motor.
Accelerating force due to stator’s rotating flux.
These forces do not all act at the running frequency[50 Hz].
So, in my opinion, the manufacturer has to state if the generator is able to run at 20% more speed.
