Eric Stromer is in the fusebox now
480sparky
Iowegia
For once, it actually looks like he's peddling good advice. I'd replace that FP (Fire Producing) panel for two reasons, though.
It's obvious he lives in an area where meter-mains and panels are all installed outside. I have yet to actually see one like that in my area.
brian john
Leesburg, VA
We had those where I lived when I was a child (So long ago) and teens would run around at night turning off the mains. They knew where the panels were located.
We were not allowed to install locks on the covers per the base engineers.
480sparky
Iowegia
Yes the breakers are allways located at the meter just like he said.
Dang! I just knew I forgot something in this last service............
brantmacga
Señor Member
Georgia
Former Child
what's up with the gutter in front of your LB?
I noticed it looks like you used two-hole straps for that 2". Have you ever tried using conduit hangers instead? I prefer them because they hold the pipe at the same distance off the wall as the hub does. And you don't have to "force" them around the conduit.
480sparky
Iowegia
Like how anyone is supposed to get the cover off that bottom LB?
Move the gutter. They're surprisingly lightwieght. Only a pound or so.
I've always used 2-hole straps for risers. I feel they hold the pipe in place better and aren't as likely to deflect as a minnie would. Besides, there's two anchors per strap as opposed to one.
But why is everyone concerned with that when I don't have all my breakers by the meter where Eric they're supposed to be?
K8MHZ
10-4 on the two holes, but I am still concerned about the aluminum rain gutter and the device that appears to be a natural gas regulator.
To be even more picky, I note a lack of provision for box offsets. Using one holes with back straps, to me, is a better method if no provision for offsets are incorporated.
Our POCO want drip loops. (I see none in your pic) and a max meter height of 5 feet. Just curious, what is the meter height, and what is the height of the lowest point of the triplex to finished ground?
Don't take this personally, I live in the Land of the Code Nazis and now think like them when I see other sparky's work.
480sparky
Iowegia
The house is going all-electric. The gas line is dead. Why is the rain gutter a concern?
Box offsets for 2"???
POA only needs to be below the w'head. I left plenty of 2/0 for a drip loop, but the line crew didn't bother when they crimped it up. The triplex is about 10'6" and goes uphill to the pole.
Jraef
Moderator, OTD
Electrical Engineer
I like the interior panel mounted in the outdoor enclosure.
Probably was a solution to replacing an old plug fuse box with breakers. I have seen that several times where the HO did not want the exterior wall patched. Nothing wrong with it really, there is no difference in the interior components or breakers between an indoor and outdoor panel, just the box, cover and trim. I would have fashioned a additional trim plate to cover those conductors however. I'd be willing to bet that a Flush trim package would have done that nicely.
quogueelectric
new york
Sorry 480 you just happened to stop on the tracks in front of the get the cow train. If I had posted the panel is allways where the meter is they would have been on me like stink on a monkey. They give stromer a pass like he is the messiah until I point out the obvious then it goes back to a catfight. You are one of the few to catch my sarchasm and are taking the brunt of the abuse. I appologize so please direct all abusive posts towards me where they belong I have broad shoulders and am used to it.
