estimating on percentage
formula1
has anyone ever heard of electrical being 10% of project total i work in an area where 90% of the work is high end second homes this economy is making me crazy with the damn low bidders doing work for nothing stay home or
StreamlineGT
I have heard that, but it's not always the case. I am doing a house right now that will be $615,000, but I am no where near $61,500 in electrical. Even with me supplying the entire lighting package, I am only around $40k. The price for this house has a lot to do with all the mill work, so doesn't effect me all that much. Each house should be given individual attention if you plan on being competitive. I realize there are plenty of people doing work right now for peanuts. People eventually realize that the work will be not to their liking, and stick with the reputable contractors. It's all a phase, and if you can make it through it, you can make it through almost anything. Keep your chin up.
AVD001
In my area, the norm would be around 3% of the overall job goes to electrical. I too work in the high end custom homes 1M to 2.5M. I do not supply any of the fixtures so that my affect the overall percentage.
marcerrin
I agree. This is the number that I've heard, floated by more than one contractor in my area.
This is an interesting question. Obviously it will vary from job to job and especially type of construction but I have often wondered what the break down is between trades. By definition there must be an "average", not one that I would generate estimates from but something for reference. Are there any cost books out there that will breakdown plumbing, electrical, HVAC, concrete, steel, carpentry etc etc as percentage of job cost for different types of construction- custom homes, tract homes, TI's, ground up commercial, remodels and so forth?
CopperTone
MetroWest, MA
back 6-7 years ago when I worked for an EC - we did electrical jobs in the 2-3 mil range and my boss used to say - in general figure about 10% of the job is electrical.
But, I think you can only arrive at that percentage after you do a complete take off and find the percentage that way.
I have found in the past 2 years the electrical jobs we have been bidding has been running 4-8% of total job cost. Some of course run much higher depending on the scope of work but for a complete remodel with all trades I've seen the 4-8%. I also think this is a low pricing current market. when time are betting you will probably see the 10% average again.
Just my opinion.
Just my opinion.
I'm not sure I follow that. If everyone is pricing low wouldn't the percentages stay the same with the actual numbers being lower? Do you feel it is just EC's that are lowering their prices? The relation in prices between trades should remain fairly steady as a percentage regardless of what the numbers are.
3%, 4-8%, 10%, what are those numbers based on?
The actual selling price of the home?
Or the cost to actually build the home?
The amount charged to the customer for the remodel/addition.
For example: on a $100K addition, $10K would be electrical
Again, not the way I bid it, but if a general contractor is trying to put together a quick WAG for a customer, it will work.
hardworkingstiff
Wilmington, NC
I fail to understand how the electrical work can be a given % of the cost to build a building due to the following:
Copper cost can go up while other building materials may actually go down (EC gets the shaft).
Fancy stuff that does not require electrical work could significantly increase the cost of the building, why is the EC entitled to a share of that?
I'm sure there are more.
Easy:
The overall job cost is $450,0000 (the cost the general charges the customer)
The electrical portion (what the EC charges the GC is $46,000)
That's roughly 10%.
I certainly don't bid this way, but just this morning, a GC called me about a 6 unit condo complex. He was trying to see if he could do the job for $100 per ft.
My extremely rough estimate helps him to see if the job can reasonably be done without either of us investing too much time in a job that either can be done or can't possibly come to fruition. If it's feasible, we'll get down to a real estimate.
ohm
Birmingham, AL
I used to work for a large design/build company. When we had to do an estimate we labored long and hard to come up with a number but the piping design leader was pretty laid back.
After many years he developed a program where he could input, among other things, numbers from the other disciplines during the meeting, into his laptop and come real close to what his estimate should be.
ceb58
Raeford, NC
When my oldest son built him house I gave the contractor a normal price for the elect. so they could come up with a total for the bank. After every thing was settled the bank gave him a draw sheet with what % amount he could draw on each task. The electrical for rough and trim was 3% of total, fixtures were 2%. Lucky for him I gave him a discount on labor:D
Mike Lang
New Jersey
I'm just curious what is the total sq footage of this house your working on? I'm guessing around 7000-7500
I've heard of people doing $5 a sq foot in my area on average tohigh end homes to figure out the cost. When I add up all the outlets, lights , and switches it 's pretty close unless they are builders grade job.
Engineer83
Wisconsin
Usually the 10% rule is a nice ball park for NEW commercial projects. Resi numbers vary quite a bit on the fixture packages and any automation systems.
