mdshunk
- Right here.
I would too (assuming the building is only 50 feet longceltic said:IF there is to be a house panel, I would definitely go with 1 GFCI to serve ALL the condensers from the house panel.
mdshunk said:Meter on the garage, panel in the garage, and each townhouse was subfed underground from its respective garage.
You'd have to sort that out for yourself. Home run wire savings vs. cost of subfeed cable and required disconnect. Might not even have the real estate upstairs for a panel. I'd put it in the garage just for the simple reason that this is "where it belongs".frizbeedog said:Any advantage to having your panel on the second floor?
Nope. Townhouses. Surely you have those in The People's Republic of New Jersey. :grin: No common areas on them. Just a bunch of otherwise normal houses smashed right next to each other.celtic said:So it's a condo now.
QUOTE]
Condensers not grouped. In each unit's backyard.
Dont' think 1 from house panel would satisfy 25'
mdshunk said:Nope. Townhouses. Surely you have those in The People's Republic of New Jersey. :grin: No common areas on them. Just a bunch of otherwise normal houses smashed right next to each other.
They seriously don't have townhouses in Jersey? Brownstones, maybe? Same thing.celtic said:I'm trying to picture the layout...that's probably some of the confusions. :smile:
I have a mental image of an apartment building being converted to condo.
If it's t'houses all grouped....any site lighting...ie, parking, path lighting?
celtic said:If it's t'houses all grouped....any site lighting...ie, parking, path lighting?
If they're going to be sold individually, no place to mount one anyhow, even if you wanted to. I have done an "owner meter" for the sign entering a development before, however. It's normally mounted on the back of some fancy brickwork piers or something along those lines.frizbeedog said:I'll have to check plans to see if it is required by builder. (A house panel that is.)
mdshunk said:They seriously don't have townhouses in Jersey? Brownstones, maybe? Same thing.
and strip clubsceltic said:Nope, just apartment buildings and factories.
LOL
Of course we have t'houses....I was stuck on the condo concept for some reason :-?
