lwilmot
- Pensacola, Florida
Yes, I have read most of the topic and Art 810.15 regarding this topic and I'm prepared to get beatup. At the university a contractor is install 1 1/2" metal goose neck antenna mast for wireless ethernet receivers. They are anchored to the side of two story concrete structures not within reach from any windows or doors. The cable running to the antenna is CAT 5 and the shield is grounded at the mast and to the equipment grounding system inside the building through the actual data unit. The sytem ground is only available on the other side of the building (several 100 ft away). Does the scope of art 810 cover this type of installation. It doesn't seem to read like it does. My rub is that art. 810.21 is for Receiving Stations which references art. 810 which does not list this type of application as part of the scope.
Have I gone to the dark side or simply gotten lost?
Appreciate any ideas,
Le
Le
