- New Jersey
- Journeyman Electrician
Is there anything required (other than the cable) in Chapter 8 for a shed that has ethernet run from a switch in the main house?
I mean something like grounding like you need for a phone line to a separate structure.Not sure what you mean. I would use pvc and, of course, underground cable.
I've never done it but will be doing it soon so I was wondering if there was a device needed on the shed end.I see. I don't think that is necessary, at least we never did it.
Yes, Cat 6 which is unshielded.
Pre-terminated fiber and media converters do the job. Depends on the distance needed- 100'? CAT6 or 5; 300'? I'd go fiber even if it's in-spec for copper (and the installation cost is going to well exceed the materials/electronics).Best practice is just use fiber but for homeowner situations paying someone to terminate it and the extra cost of fiber switches may not be worth it.
They make what's effectively a "consumer" level, but in any case, you're playing for quality and support; they're kind of like the Apple of wireless networkingThese days mesh networks work so well though that it’s cheaper just to get some meshing WiFi radios and enjoy coverage both inside and out on the lawn. I prefer Ubiquity but that’s professional grade. TP Link is a close second.
Works for me all the time.Google has proven themselves not trustworthy.
Correct, but in case I'm using UTP. Hardwired Ethernet is all that will be needed in the shed.CAT 6 comes in UTP and ScTP. Depends on what you order.
In audio, a shield connected at only one end is normally done so at the receiving end, so the entire group of equipment upstream doesn't become part of the signalAdding a shield as in 6A would complicate it a bit, but I have read the shield should only be bonded at one patch/ switch.
That would be covered by Article 725 and nothing special unless the cable is exposed to lightning. That would trigger 725.41.Is there anything required (other than the cable) in Chapter 8 for a shed that has ethernet run from a switch in the main house?
That makes sense, and from what I read its the same reason. Keep the shield as a shield and not risk having any current flow on the shield between the two points.In audio, a shield connected at only one end is normally done so at the receiving end, so the entire group of equipment upstream doesn't become part of the signal
